Kioti KB2485 Backhoe Hoses ?
   / Kioti KB2485 Backhoe Hoses ? #1
Tigershark
Shelby, KY
KIOTI NX5510 Cab HST with Backhoe
I have a Kioti KB2485 backhoe and I'm trying to hook it up after having it disconnected for a few months. Problem is it weighs a ton and even on a few dollies it's not perfectly level so I am trying to hook up the hydraulic lines so I can lower the feet and raise it level problem is I can't get it close enough to hook up to the remotes so does anyone know I can buy some longer hoses to utilize putting the feet down to raise the frame even? I know it's a basic question on hooking up some auxiliary hoses to add maybe 5-6 more feet in order to use the hydraulics so I can level the frame out then back the tractor into place. Sorry if this is a stupid question just looking for something that makes hooking up the backhoe a little easier. Thanks for any advice
   / Kioti KB2485 Backhoe Hoses ? #2
The hoses should have QDs on them. It’s easy to buy some generic pre made hoses and add a set of male and female QDs.
I keep several of these hoses around. I know I’m bound to break a hose when I can’t run to a shop. I guess I’m just saying having the hoses may be good thing for a future need too.
Matching up the QDs May take a little homework. Or you will need to take a male end to a local shop.
   / Kioti KB2485 Backhoe Hoses ? #3
Hi, My local Napa dealer builds hydraulic hoses. Check around with some of your local ag or auto parts dealers. Rather than replacing the stock length hoses and having access length hose when the BH is attached to the tractor, maybe have a couple of extensions built that can be used just for times like this? I have the same BH on my NX6010. Building hoses is always cheaper than ordering OEM replacements.
I'm just looking for something I can connect the factory hoses to temporarily to add 6 ft then disconnect once I have it level and connect BH to regular hoses once the BH is mounted,
   / Kioti KB2485 Backhoe Hoses ? #5
Both of us have pointed you in the same direction to accomplish your task. What further info are you looking for?
Got it thanks, pulled the connectors off to take to NAPA hopefully tomorrow to build the extension hoses. I have several extra hoses for the tractor but the fittings are different. Hopefully I can get something I hate trying to move that thing on the dollies it will be much easier to hook up the hydraulics and set the feet down and be stable. Thanks for the advice
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2017 Bad Boy...
