Kioti - Flashers / Blinkers / Indicators permanently on NX4510
   / Kioti - Flashers / Blinkers / Indicators permanently on NX4510 #1
LondonVermont
Vermont
TBC
Hi, I wonder if I could get some advice.
The tractor is kept dry in a garage. One day when I turned it on the flashers started working without the switch being used.
If I un-plug the rocker switch, they still flash.
If I unplug the bulbs by the ROPS and remove the switch, the display panel still flashes.
I've traced the cables from the switch all the way to the bulbs and there appears to be no worn or damaged cables, no visible mouse damage.
I've removed each relay (beside the fuse board) but that has no effect.
If I turn the key to off, it stops flashing.
If I remove the flasher/horn fuse it stops.
The dealer has no idea what the cause may be and can't even tell me where the correct relay is or what it's re-order part# is. (He's a new young kid)
Any ideas?
   / Kioti - Flashers / Blinkers / Indicators permanently on NX4510 #2
Most flasher system (not computer controlled) work on the principal that current flow (amperage) through the lsamps causes flasher to operate, providing power is supplied through some controlling switch.... IF its a computer controlled flasher circuit, good luck.... Problem a may not be turn signals but emergency warning flasher circuit....
John Deere 950A Zero Turn Mower (A50860)
John Deere 950A...
2011 Ford F-150 Pickup Truck (A50860)
2011 Ford F-150...
2015 Jeep Cherokee SUV (A48082)
2015 Jeep Cherokee...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2004 John Deere 9320 Articulating Tractor (A50860)
2004 John Deere...
2006 International 4400 LP Ambulance (A50323)
2006 International...
