Kioti DK65S question
   / Kioti DK65S question #1
bazman82
Lockport, NY
Same Mercury 75 Farmtrac 795DTC
I found a Kioti dk65S (Perkins 3.3L 3cyc) and I am not familiar with these tractors but read that they are a decent tractor. The sound the tractor makes, seems to be a bit different than what I am use to (ford, same, LS). I watched a few videos of other Kioti tractors and it sounds similar to them. I assume because the engine is made by a different company?
   / Kioti DK65S question #2
Smaller tractors generally use three cylinder engines now. Larger tractors still use four cylinders though the size change varies by brand. Many older tractors used four cylinder engines though some used two or three cylinders, too. That could account for the different sounds made by different tractors.
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2018 Toro Sand Pro Bunker Rake with Edger/Broom (A49461)
2018 Toro Sand Pro...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
