Kioti DK55 Power steering issues
   / Kioti DK55 Power steering issues #1
jimglassford
Manchester, mi
Kioti DK55, Ford/New Holland 4630
I have a 2003 DK55 with 2600 hours. It hase been a real money pit. I now have an issue with the power steering. You can rotate the steering wheel as many times as you want when turning. When going is a straight line, you constantly have to correct with the wheel rotating one direction. This tractor has the earlier single acting hydraulic cylinders on the front axle so the problem can't be leaky seals. I see others have posted the same issue on smaller Kioti's. However, no one has ever diagnosed the problem. I see a few members state they finally just took the tractor to the dealer but never reposted the repairs made at the dealer. I believe there is an internal problem in the steering control valve. My repair manual tells you home to disassemble the unit but I do not believe parts are available.
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
1240 (A50490)
1240 (A50490)
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
