Kioti DK40 3 point wont go up.
   / Kioti DK40 3 point wont go up. #1
chopped
New England yankeee
Greetings,
A friend has a less than 2 year old tractor. The 3 pint was working fine then we lowered it and it wouldnt go up again.Checked the hyd. fluid and added some as it was down slightly.
No luck.
It has a draft control but dont think thats the problem..
any ideas.
   / Kioti DK40 3 point wont go up. #2
Greetings,
No luck.
any ideas.
That does not sound particularly good. Is the draft control (they yellow handle) all the way forward and you are using the orange handle to raise the 3pt?
I am sure you are, but just checking.. So either a piece of debris in the valve, or seals in the cylinder? Just a guess.
Also make sure both (if equipped) of the rear remote valves are centered in neutral. Remember one of them comes with a detent standard from the factory. Joystick of FEL not in float position? For that matter is FEL operation correctly. If not could be stoppage in suction side of pump. Like filter clogged.
Thanks very much.I wlil pass this along. The remote valve part you describe was something I was thinking about..
Yes on the levers .I know he had the draft(yellow) all the way forward.
My thought is it should be something simple as its so new and low hours.
what would you think about the oil being low ? when he added some and got it to where it should be it still doesnt work.I wouldnt think it could be air pockets?
   / Kioti DK40 3 point wont go up. #4
Check the draft dial below seat. Its the round dial. If its rotated too far in one direction, the 3 point wont lift
   / Kioti DK40 3 point wont go up. #5
Thanks everyone. This turned out to be one of those things that he is simple user error lol The Remotes lever was in between the two functions.Simple as that....My friend doesn't use the internet but is thankful for the problem solving here.
Thanks again...
White Metal Roof Panels (A55758)
White Metal Roof...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
120 Gallon Tank (A56469)
120 Gallon Tank...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
UNUSED FUTURE 10' GALVALUME CORRUGATED SIDING (A57193)
UNUSED FUTURE 10'...
2020 POLARIS 1000XP RAZOR (A57192)
2020 POLARIS...
