KIOTI CK3510se PTO Output Shaft Not Free Wheeling/Free Spinning
   / KIOTI CK3510se PTO Output Shaft Not Free Wheeling/Free Spinning #21
Thanks.. It just wouldnt show in a search for me.. Found the 1 3/8 to 1 1/8 one though :)
Didn't show up to me at first. For some reason they called those a coupler. It ended up showing on the suggestions.
Can you link that, please? Not finding it on AgriSupply
RLS1 Overrun Coupler 1-3/8 In. 6-spline
Item #90654
$35.99 + $9.61 shipping
In Stock
I picked this one rather than the ones with the roll pin attachment.
And being less money didn't hurt....
   / KIOTI CK3510se PTO Output Shaft Not Free Wheeling/Free Spinning #23
I like the over-run clutch idea. I had a larger Cub Cadet with electronic PTO. Hated it. Though I could put it in neurtral for hooking up equipment, I popped a lot of shear bolts on the rotary cutter until I put a clutch on the shaft--either engaging or disengaging at too high an RPM. The belly mower would pop the belts off if I engaged or disengaged the PTO at too high an RPM as well.
   / KIOTI CK3510se PTO Output Shaft Not Free Wheeling/Free Spinning #24
This is the first tractor I've owned with the electric PTO engagement. HST (no clutch), no mid PTO just rear and no neutral or disengagement lever for PTO. Just the round yellow engage/disengage switch. Is it something I've missed or is it no longer possible to turn the tractor PTO output shaft freely while attaching an implement? My KIOTI requires that I rotate the flail or rototiller or mower blades or rotor by hand to align the PTO shaft splines with the splines on the tractor PTO output. Previously I could just rotate the tractor PTO shaft easily to align the splines. If I was 40-50 years younger or had a helper working with me all day it would be easier to make the connection.... I currently have my wife pushing/pulling on a crowbar when changing implements but she doesn't appreciate being on call all day. Dealer says that's the way it is. Of course I didn't try to hook anything up that uses a PTO before I paid for it and had it delivered. 😶‍🌫️😵‍💫🤠 Thanks-Paul
My New Holland tc45dh hydrostatic tractor’s pto shaft doesn’t turn freely either. Sometimes I have to start the tractor and engage and disengage the pto several times to get the spline liners up.
   / KIOTI CK3510se PTO Output Shaft Not Free Wheeling/Free Spinning #25
I'm amazed I have not heard or read about my issue before. Thanks again
Well, in my case, i have been able to turn the shaft connected to the implement by hand (bush hog, mower deck, post hole auger) and never knew any better - maybe because I was born in Queens with Trump and never owned a farm implement 'till I bought the Kubota and it's attendant implements and trailer when I retired as a halfback from Florida.
I have the Hydrostatic business and never thought to try and turn the stubby spline shaft at the tractor; never tried to and, therefore can't say if it can be turned. Maybe next time I change implements . . .
"If the tractor doesn't have a lever to select between different PTO gears or between mid and rear PTO"
Mine has a lever for the mid and another for the rear PTO - Engage or Disengage are the options for each. As I recall, I have to depress the clutch pedal to engage either (and do so to disengage them as well).
But, when the tractor's not running . . . are those two output shafts 'engaged' or free wheeling? I do not know.
   / KIOTI CK3510se PTO Output Shaft Not Free Wheeling/Free Spinning #26
Well, in my case, i have been able to turn the shaft connected to the implement by hand (bush hog, mower deck, post hole auger) and never knew any better - maybe because I was born in Queens with ***** and never owned a farm implement 'till I bought the Kubota and it's attendant implements and trailer when I retired as a halfback from Florida.
In your case, since your tractor uses a dry clutch to engage the PTO, all you need to do is to put the levers in the disengage position and then you should be able to turn the PTO shaft by hand easily.
2007 JLG Skytrack 8042 8K Capacity Telehandler (A59213)
2007 JLG Skytrack...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
2015 Parker Trailer (A57148)
2015 Parker...
2170 (A58376)
2170 (A58376)
Giyi 40" Land Leveler (A57149)
Giyi 40" Land...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
