Kioti CK27 HST
   / Kioti CK27 HST #11
Am not aware of any adjustments
There are, and they helped, but didn't fix the issue. My dealer did them since the tractor was less than 1 yr old so I don't know exactly what they are, it's something like a tension spring or similar that can be tightened if memory serves.
In order to diagnose the issue, my dealer lifted the rubber floor and there are two ports near the back in the centre. They put a pressure gauge on them and they read low when the pedal was pressed. That's what they told me they expected to happen before they tested it, I was there when they did the test and that's what they said the result was. Sorry, I don't know what the proper pressure range should be, just that it was low and that indicated a cooked HST. This test was at Kiotis request and had to be done before a new hst was provided. I'm sure a dealer can help you with the pressures if you have a tester.
   / Kioti CK27 HST #12
chase729 said:
Icannot find any grease fittings Only way to lub is to spray exterior
Double check there should be a grease fitting.
2017 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2017 International...
2008 International 4300 Water Truck, VIN # 1HTMMAAN58J687362 (A57453)
2008 International...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2139 (A58376)
2139 (A58376)
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
