Keep blowing fuse for fuel solenoid CT445
   / Keep blowing fuse for fuel solenoid CT445 #1
bmillerag
Flat Rock, Indiana
bobcat ct230
i have a Bobcat Ct445 that I keep having problems with. Last fall the starter would have a hard time cranking the motor and acted like it was slipping. I replaced the starter. After the starter was replaced I noticed that my fuel solenoid was not clicking when I turned the key. The motor would just turn over like it should but wouldn't fire. I replaced the solenoid. After replacing the solenoid when trying to start the tractor the starter would make the same noise as it would before I changed it out. The only way I can get it started is to jump it with my truck battery. I thought maybe my battery was low so I put it on a charger over night and still wouldn't start with out jumping it with my truck. Once I get it started if I shut it off immediately I can restart it. If I run the tractor for a few minutes I blow the fuse for the fuel solenoid. If i put a new fuse in it after shutting it off I will have to jump it to get it started again. I have replaced the battery with a larger CCA battery. It make no sense to me what is going on. I have noticed since this happened that I don't have RPM reading on my dash as well as the H or L light once i get it started and my hour meter isn't working. Any ideas would be greatly appreciated.
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A46683)
2006 GMC C8500...
Kivel 48in Pallet Fork Attackhment (A49251)
Kivel 48in Pallet...
Kivel 48in Pallet Fork (A49251)
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
New Holland 853 Round Baler (A49251)
New Holland 853...
Cart (A46684)
Cart (A46684)
