KAMA Sticky Solenoid
   / KAMA Sticky Solenoid #1
3RRL
Super Member
Foothills of the Giant Sequoia's, California
55HP 4WD KAMA 554 and 4 x 4 Jinma 284
I've had some problems with my KAMA solenoid not engaging the starter motor. I"ve read where others had similar problems so I thought to post this.
Chip at Artrac had mentioned to "clean out" and lube it in another thread and that's just what I did. It was very easy and took about 10 mimutes to do. I noticed that the sticky solenoid problem was getting worse and worse so I decided to clean it before even attempting to start the KAMA for the first time. It began to happen more frequently upon starting...usually 5 or 6 times over the course of each weekend and usually everytime the first time I tried to start the KAMA. I found the solenoid piston had a deposit of gummy stuff on it, hindering its sliding movement inside the solenoid body. After this cleaning, the tractor started immediately and never had a failure the entire weekend.
Hope this helps those of you who complained about this problem.....simple solution...thanks Chip.
-Disconnect the batterry terminals
-Remove nuts that connect the copper connection from the starter motor to the solenoid
-Remove the 10 mm bolts that hold the solenoid to its mount
-The solenoid body will have a spring in it, that goes around the piston
-Slide the solenoid body CAREFULLY off the piston inside
-The piston is connected to a lever via a spring loaded plunger and hook arrangement and can be tricky to re-assemble
-Keep the piston attached to the lever if you can
-Run some fine emory cloth or wet & dry 320 with kerosene to clean it off
-Do the same to the solenoid body (inside)
-Wipe dry and clean and apply lubricant to both(I used gear oil)
-Slide the body back onto the piston
-Bolt back together again.
   / KAMA Sticky Solenoid #2
I had the exact same problem with my starter. I called Chip and he advised me of the same, it worked great. Also, I highly recommend changing all fluids, oil, differential, radiator, gear box, hydraulics, etc...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
13 Desktops (A48083)
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
