I was asking if you couldn't just move the PTO lever going into the transmission. Bypass the cable. That is if you need to get it going badly enough.Fisrt time it broke, I could grip the wire with a vicegrip and pull it. This time it seems the wire is cut at the level attachment and has slipped into its envelope. Didn’t find an easy alternative solution yet…
The spring is to help it stay OFF so if the cable doesn't lock in the ON position, it will naturally kick out of gear. (I just tried to do that!!!)I was asking if you couldn't just move the PTO lever going into the transmission...
That’s why Vicegrip worked …The spring is to help it stay OFF so if the cable doesn't lock in the ON position, it will naturally kick out of gear. (I just tried to do that!!!)
