Just noticed this .
   / Just noticed this . #1
kevin37b
Veteran Member
mansfield,Il
john deere
I have noticed on the boom cylinders on these compact loaders , the barrel of the cylinder goes with the boom instead of the rod . That means alot of flex in the plumbing . Why ?
   / Just noticed this . #2
The only logical answer I can think of is for loader removal. Everything goes with the loader, sometimes including the valve.
   / Just noticed this . #3
You will have a lot flex in the lines if mounted either way. It is to make the lines to the boom cylinder on the other side shorter, then if mounting the barrel down and rods up. Another benefit is the seals are mounted down, less chance of dirt settling in them and getting pulled in.
JJ you are not on the same page . I am talking about the cylinders between the mast and the boom . All the excavators or TLB's I run the rod moves , the barrel is stationary . It is like the cylinder is upside down . And no you do not have alot of flex either way Z5 . The fittings are on the barrel not the rod . I wish pictures . JJ you are a master of all , peace and good will .
2001 Great Plains 3N-3010P-4875 Grain Drill (A50657)
2001 Great Plains...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
Toro Z Master Mower (A50324)
Toro Z Master...
