Just had a sickening thought
   / Just had a sickening thought #11
'Risk Management' is what the OP has done and it's what we all do, mostly unconsciously, whilst performing any task. Mostly it's a "what could possibly go wrong" analysis of the situation.
You reduce the risk to the lowest possible acceptable level and then get on with the job.
... Or wrap yourself in cotton-wool & bubble wrap and never leave your bed.
   / Just had a sickening thought #12
Sounds like you've been some FMEA's! We have to do them at work on some of the products we manufacture. All of our products are used on railroad tracks, most of it used to control track signaling, crossing guards, track switches, and CBTC (communications based train control). A lot of that gear is considered to be "vital safety" which is critical to trains operating in a safe manner.
Anyway, back to the OP... if the rear tires are loaded, doesn't that reduce the chances of a tire blowing out? The air pressure will be lower (I think), and there is less volume of compressed air above the liquid ballast. Also, I would think that the liquid ballast would tend to help dampen out any explosion. Or am I just daydreaming here?
   / Just had a sickening thought #13
I have a NH 3930 and I was going to hook up my utility trailer to my ball on my drawbar. I placed the drawbar and then crawled under the tractor to put the pin through the frame as I have done many times. As I was struggling to get the pin in, I had the thought that if the tire were to blow out while I was doing this, I would be a dead man.
Have never heard of a tire doing this but I am sure that it has probably happened before. Know the odds of this happening while under the tractor is very small, it still is a little scary. Wonder if I should put something under the frame in the future?
I have many things to say. But I'll refrain.
It's more important that you remember to latch the ball on your utility trailer.
   / Just had a sickening thought #14
You were doing so good...... Then, I'm not sure what happened..... :)
   / Just had a sickening thought #15
I'm personally lose more sleep worrying about the possibility of reality fluctuations. Something like the north pole relocating, only MUCH worse.
   / Just had a sickening thought #16
I'm more worried about harbor freight running out of free batteries.
   / Just had a sickening thought #17
Over reacting or over thinking ? Perhaps so. Or perhaps ones subconscious ringing a bell that one should pay attention to ? Only you can make that decision.
   / Just had a sickening thought #18
I had a student who over the summer was working under his car. He was using a piece of firewood for a jackpost. The car came down and crushed him. His pregnant girlfriend found him.- Just be smart and think ahead - like not walking under the bucket, or as I used to like to do- slipping under the belly of my horse rather than walking around.
   / Just had a sickening thought #19
While it's never a bad thing to be safe, you can also think yourself into neurotic paralysis. I've never heard of a tire blowing and instantly deflating while it's just sitting there. It's possible that it has happened, but ...
I wouldn't worry about what you are doing but I watched this video a while back and was shocked with the force a tire blowing out has.
   / Just had a sickening thought #20
I've thought about it but decided it wasn't a significant risk. Getting rolled over is far more likely to happen. I do set the parking brake and scotch it if it's on an incline. My tractor has enough ground clearance I'd probably be alright if it happened. Vehicles usually don't.
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2017 John Deere 6105E (A57148)
2017 John Deere...
1703 (A58375)
1703 (A58375)
J and L Cargo Express Shadowmaster Enclosed Trailer (A56436)
J and L Cargo...
Butler MFG Water Tanker (A56436)
Butler MFG Water...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
