Jumping out of 4 wheel drive
   / Jumping out of 4 wheel drive
Arlen, What is GTT?
   / Jumping out of 4 wheel drive #12
Green Tractor Talk. It's another forum. The fix was from JD, and the tractor has to be split.
   / Jumping out of 4 wheel drive #13
Yes you are a bit off your rocker, the tractor came with R4 tires from the factory and that is why I mentioned it here back in 2011 and there was a slew of owners with the same problem. From drawings of the system we figured there was a possible weak spring problem but no one back then had solved it either by themselves or by their dealers. And as usual JD didn't want any part of it.
Thanks to Arlen 4720's post below I see that I may have been right all along but I wouldlike to read a little more on what or who came up with the fix. I know it won't be a simple job to pull this system down, but there are no JD dealers here in the VI so I'll just live with it for now till I get up enough courage to take it on.
VI? would that be Virgin Islands?
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
1086 (A58374)
1086 (A58374)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
LOT: (4) Jack Stands (A59076)
LOT: (4) Jack...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2005 John Deere 200C LC (A55272)
2005 John Deere...
