Jump start tractor with truck?
   / Jump start tractor with truck? #11
Man's leg crushed in tractor accident
If its an older gear tractor its wise to have no one between tires on side . Might not be in neutral and start in low gear .
Its always good to be sittin down in seat when attempting to start .
   / Jump start tractor with truck? #12
if you are worried about the battery just drag it with the truck and pull start it - unless of course you dont have someone to drive both ;-)
Perhaps this is a starter for a new topic, but I wasn't aware you could pull start a tractor with a hydrostatic transmission or even tow it for that matter without disengaging the HST somehow.
Yet another benefit of having a gear transmission. Not meaning to start a fire, just had to get one more whack on that dead horse!
   / Jump start tractor with truck? #13
The quality of your jumper cables will be the next issue. If the battery is good and just needs a charge to get back up to speed, then most any jumper cables will handle the issue if you give them enough time. If the tractor battery is dead, beyond charging, then it takes a very good set of jumper cables to handle the load of the starter if it all has to come across the jumper cables during the start period.
I got tired of jumper cable issues and bought just the clamp ends at a local auto parts store, and then used #1 welding cable for the conductor. Worked so great, I decided to build another set, but this time I used 2-0 welding cable. Trust me, I have very few issues getting the power to whatever I am jumping off. The biggest issue is the weight of a twenty foot set of jumper cables now...
David from jax
   / Jump start tractor with truck? #14
nice catch...........yup looks like it is an HST from his column on the left i missed that - i don't think you can drag a hydro to start it, back in the day.........you could start pto to pto if you knew your stuff or also using a belt if you knew whether or not u needed to provide twist or not in the belt.
much different now days with hydraulic engagement on PTOs and lack of a belt pulley or gears
   / Jump start tractor with truck? #15
This guy uses PTO to start. Works along as you don’t have a overrunning clutch.
Would it work on a hydro too?
Starting a tractor by spinning the PTO - YouTube
   / Jump start tractor with truck? #16
I was taught that you should first hook the cables up to the vehicle being boosted , not last. Presuming you have been trying to start it before boosting there is a slight risk of fumes; therefore if there is an arc when you hook up the cables it will be farther away. That was 40+ years ago though, ideas may have changed.
DITTO
   / Jump start tractor with truck? #17
Internet says that batteries produce gas after they reached full charge. So it would be the booster vehicle that’s more likely to have explosive hydrogen gas present.
   / Jump start tractor with truck? #18
They were talking more about gasoline fumes, after flooding the vehicle. Ventless batteries in theory don't emit gases.
Do you plug in your battery charger before or after hooking the cables to the terminals?
As stated before that was a long time ago though, at a troubleshooting class I took just after HS.
   / Jump start tractor with truck? #20
I've had a battery explode on me before. I hooked the cables up to the good battery first and as soon as I put the negative on the dead battery BOOM it blew. since then I always hook the dead battery up first and use a different ground than the battery. It really did make a nice explosion, a guy standing about 5 feet or so next to the car had his hat blow off his head, luckily nobody was hurt.
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
2021 Kubota SVL75-2 Track Loader (A56435)
2021 Kubota...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
