John Deere X300 Choke Issue
   / John Deere X300 Choke Issue #1
JCMac
Randolph, MN
John Deere 790, John Deere X300
I have a JD X300 with Kawasaki FS541V engine. Only needs choke when it has sat for a while or cold. Problem is, the choke does not open back up when the choke lever returns from closed position. Everything I find seems to indicate a bad choke spring. Do I have to disassemble the carburetor to get at that? I'd love to fix it myself, but that may be swimming in the deep end of the pool for me. Any advice?
   / John Deere X300 Choke Issue #2
   / John Deere X300 Choke Issue #3
It could be a spring I suppose. I have one of these that the plastic choke shaft became deformed and bound in the bore. I pulled the plate and shaft and polished it before reassembly and it has been good since- about 2 years. MIU12545 looks to be the part number for the shaft.
   / John Deere X300 Choke Issue #4
Heavier choke return spring. Part # MIU13934. Your dealer should be able to bring up tech bulletin on it.
   / John Deere X300 Choke Issue #5
Can't beat that...
Part Number: MIU13934
Part Price: 1.16 USD
Thanks to you all. Looks like it's doable. I've put up with it since I didn't often need the choke and when I did, I just popped the hood up and pushed it down. Now that I put a brush guard on it, that's not so simple.
   / John Deere X300 Choke Issue #7
I have the same problem on my X324 with choke not returning. I suspect its the plastic choke shaft is deformed like mentioned above, however I thought I would try this stronger spring fix first. Will this part MIU13934 fit my X324?
engine FS651V
Thanks for your input?
Unused 2025 Spirit Mini Golf Cart (A48082)
Unused 2025 Spirit...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
Levee Plow (A50860)
Levee Plow (A50860)
2013 GMC Sierra 3500HD 4WD Cab and Chassis Pickup (A50860)
2013 GMC Sierra...
