John deere 950 rough idle.
   / John deere 950 rough idle. #1
njb347
John deere 950
I have a john deere 950 and recently had problems with them fuel injection pump and a high pressure fuel line. I bought all three new high pressure hoses and paid 1k to have my fuel injection pump rebuilt. I returned home and put everything together and now my tractor runs but it doesnt get rpms like it used too and if I idle it down some it will idle down and die. I am completely honest and dont know a ton about diesels but I enjoy learning.
Could one of my injectors be clogged? Could I remove the injectors and clean them and replace them (Dont wanna spend another 1k on getting injectors rebuilt)? Was I supposed to adjust some kind of timing on the fuel pump that controls the idle ( the fuel squirted out of the fuel injection hoses in sequence when I'd turn the key)?
Thanks I'm advance for any tips or help. Hoping I get this thing running.
   / John deere 950 rough idle. #2
Did you by chance bleed the injector lines. Really sounds like you have some air still trapped in the fuel lines. Key point to remember is that air is compressible fluid is not. I don't know if the 950 has a primer bulb but if it does you might want to crack the lines at the injectors and prime until you get a steady flow of diesel coming out of it.
Just out of curiosity what was going on that led you to rebuild the pump and replace the hight pressure line?
   / John deere 950 rough idle. #3
The ONLY thing that "wears out" an injection pump is poor fuel.. either the quality of the fuel{water} or poor filter maintenance.{dirt}
Did u refill your tank w/ diesel fuel or Bio-fuel??
Did u CHANGE the fuel filter or just blow it off?
Did u replace the washers on the inlet line to the pump or just reuse the old ones?
What about the return lines?? new gaskets??
If its all new, {pump & injectors}, its likely THOSE aren't your problem..
Those mdl. JD's{Yanmar} have a very poor filter system..
The timing is done by steel shims under the injection pump.. You did put them back on the new pump didn't you?
NO, you cant clean the injectors.. unless u take them apart.. & that's not advised..
   / John deere 950 rough idle. #4
Who installed the pump? I have got away with reusing the same quantity/thickness of shims when reinstalling the same pump on the same 950 block but the correct way to do it would be to follow the timing procedure. I believe that involves disassembly of the number one plunger on the pump but I never did it.
   / John deere 950 rough idle. #5
Your right TimberHole.. 99.9% of the time, the old shims are reused w/ no problems. Bolt'r down & off u go..
The shutting off at low idle is suspect tho.. that sounds like air in the system or poor fuel quality or supply pressure??
   / John deere 950 rough idle. #6
Could definitely be something as simple as bad fuel. I can’t help but wonder how the current symptoms compare to the symptoms that led to the replacement of the high pressure lines and the rebuilding of the pump. The high pressure lines are very simple, they’re either good or they’re not. I’ve only worked on a couple of these but I think many of these have bad washers between the injectors and the burn chambers. If those washers are bad you’re losing compression. When I’ve pulled the injectors the holes in the head are so polluted it takes about 45 minutes per hole to clean them. It would help to know the problem that started all this. I hope the OP doesn’t post this issue and then fail to return to the thread, as often seems to happen.
I know this is alot but I'll try to start from where my problems began. I got this tractor from my grandma and the tractor was just left out side even though it was in running condition when I got it I went about changing oil flushing radiator hydraulic fluid and all filters.
One day the fuel hose that goes from the fuel filter to the fuel pump started having a pretty good leak and I went to john deere and got a new 2 ft piece of hose to replace it. Apparently the old hose wasn't being made anymore as you can tell it isn't same size outside diameter because my spring clamps wouldnt work around the hose. I called john deere and went AND exchanged that piece for another piece that looked just like that one they had gave me and they swore up and down it would work. Finally after getting it back together I tried bleeding my lines and the bleed screw so that i could fire it up but the high pressure fuel line closest to the front of the tractor wasn't squirting it would just drain diesel while the back to squirted diesel like normal. I ordered all three new high pressure fuel lines in case of something in my fuel and had read on here where plungers get stuck in the fuel pump if there's a little water sitting on the plungers it may rust them. So I banged around to try and unstick the plunger and finally went to taylor diesel in little rock and got my pump rebuilt brought it home and the tractor fired up (I did buy new shims to go around the fuel pump because the old ones were worn) but it has been surging and loping since I got this done and I'm scared it may be a injector after spending 1k on that fuel pump it makes me sick to spend more.
So here's what I've considered I may have:
My fuel hoses need clamps because its sucking air.
I haven't timed it right with those shims.
This is my first time working on a diesel and I really wanna use this tractor and dont wanna give up on it and I love tinkering on it but man this thing has been a headache lately.
Sorry i haven't responded in a while we were called out to help with hurricane michael clean up and I just got home a couple days ago. I really do appreciate any help from you guys.
I dont understand how these shims work and maybe that's my problem. When I got home I just put the pump back on the tractor with the two shims John deere sold me behind the pump and fired it up. How does this work?
   / John deere 950 rough idle. #9
AHHH.. Now for the rest of the story..Lol
The shims are set from the factory to adjust the timing of injection..
They are VERY specific to your engine.. Your neighbor might have a 950 & the shimming would be/could be different.
You have to keep the right AMOUNT/THICKNESS of shims for YOUR engine..
Unless the shims were measured at JD & the same amount/thickness were handed back.. THATS a problem..
BTW> the shims don't wear out..
AMD the shims are the copper color things I put between the tractor and pump right?
What would I need to do to get it back right now that I have messed up and thrown the old ones away?
Misc Machine Tools (A50860)
Misc Machine Tools...
KUBOTA 1140CRX RTV (A51406)
KUBOTA 1140CRX RTV...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
Box blade (A50860)
Box blade (A50860)
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
2019 Toro Proline 32in Fixed Deck Mower (A48082)
2019 Toro Proline...
