John Deere 425 Zero turn Hydraulic pipe leak
   / John Deere 425 Zero turn Hydraulic pipe leak
Anyone here ever worked on or replaced the "O" rings on a TUFF TORQ BY KANZAKI MODEL: DUP 10E S/N: 10E006141, if so would you please shed some light on your experience with this unit. :eek:
Well gentlemen, I think my leakage problem have been solved.
I was topping my reservoir off with the wrong weight oil, I was using AW-10 Hydraulic fluid.
The more 10 weight Hydraulic fluid I added to my reservoir the more the leak increased.
Once I started using the correct weight oil 20-50W motor oil the leak gradually subsided.
   / John Deere 425 Zero turn Hydraulic pipe leak #12
Isn't it great when things fix themselves !
It will be back.
Richard
   / John Deere 425 Zero turn Hydraulic pipe leak #13
It will be back.
Richard
I suppose things fixed itself when the owner/operator wised up and put the correct oil in the reservoir.
Almost a year now, since I put the correct oil in the reservoir, no leaks not even a wet spot.
