john deere 410c backhoe hydraulic fluid
   / john deere 410c backhoe hydraulic fluid #1
chrisdvorak
RI
too many
where is the hydraulic tank located on a 1986 john deere 410c turbo backhoe? I also cannot seem to find the fill cap or dipstick? any help would be appreciated.
-thanks chris
   / john deere 410c backhoe hydraulic fluid #2
hyd oil dipstick parts key #9. I couldn't locate hyd oil filler cap in parts schematics.
That seems to show the dipstick going into the shuttle, i would think there would have to be a hydraulic fluid tank? As it holds 21 gal of fluid.
   / john deere 410c backhoe hydraulic fluid #4
The trans/differential housing/hyd system is the hyd reservoir.
oh that makes sense, so which one of these dipsticks is for the hydraulic fluid and which one is the transmission? I assume you would just fill through the dipstick tube? as there seems to be no fill cap.IMG_0424.jpg
Nobody knows where to add hydraulic fluid on a 410c backhoe?
   / john deere 410c backhoe hydraulic fluid #7
Since I was employed at a JD dealership that was an agriculture only dealer my industrial tractor knowledge is limited. Have you given any thought to purchasing an operators manual for your machine? The many operators manuals I've read have some very valuable info. in them.
   / john deere 410c backhoe hydraulic fluid #8
I would say add it in the dipstick tube. It won't hurt anything may just take longer to fill.
   / john deere 410c backhoe hydraulic fluid #9
On a Deere 310C the fill is a hex plug on top of the hydraulic tank. Look there on your machine...
Where is the hydraulic tank located on the 310c?
New Holland LB75B (A57148)
New Holland LB75B...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A56858)
2016 Ram 4500 Crew...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A56858)
2013 Ford F-550...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
