John Deere 2010 Turbulence Chambers
   / John Deere 2010 Turbulence Chambers #1
danpaul1
Athens, TN
John Deere/2010
I took all four of my Turbulence Chambers out of my John Deere model 2010, I noticed none of the holes in the bottom of them were the same size the different's is any where from 3/16" to 5/16". My question does the different size in the bottom of the turbulence chambers matter? I'm afraid that I've made a mistake when taking out the four turbulence chambers, I did not mark which one goes where I assumed they were all interchangeable because, I did everything by the shop manual "Word for Word" that I have, the manual did not say anything about putting a mark on each chamber (So I would know the one that came out of the cylinder head hole #1, #2, #3 and #4 front to back or left to right standing on the left side on the motor).
Does anyone know how I can tell which Turbulence Chamber came out of cylinder head hole 1, 2, 3 and 4? I used my "Micrometer" to check the measurements on each one of the chambers to see if they were different, they are not different in any way, I looked for any kind of factory markings on them that may tell me which chamber goes where and the only letters and numbers stamped on the chamber housings at the factory ("BH" on three of the chamber housings and the last chamber housing only has and "Arrow Symbol" stamped on the front of the housing).
Thank you
DP
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
Air vents for roof (A50860)
Air vents for roof...
1264 (A50490)
1264 (A50490)
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
