john deere 1520 hydraulics and draft settings
   / john deere 1520 hydraulics and draft settings #1
traded
NY
John Deere 1520; John Deere 5420
Good evening, I tried adjusting my hydraulics on the 1520 because I would have a hesitation at times when trying to raise the hay rake (John Deere 350). When making the adjustments I wasn't able to get the draft setting into the "D" setting but able to go through LD and L. Are there any suggestions out there for the cause of this. I would really like to continue using this tractor for light field work but hydraulics are a must. Thanks for your help!
   / john deere 1520 hydraulics and draft settings #2
My guess is cam follower(shady outlined part) isn't in correct location in 3 pt linkage,is possibly broken or spring is broken. Either problem would require R&R of rockshaft housing.
I'll have to pull the cover off later this week and see what's going. Thank you for the help, I'm sure I'll be back with further questions.
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Lot of 3 Dell...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
