john deere 1520 hydraulics and draft settings
   / john deere 1520 hydraulics and draft settings #1
traded
NY
John Deere 1520; John Deere 5420
Good evening, I tried adjusting my hydraulics on the 1520 because I would have a hesitation at times when trying to raise the hay rake (John Deere 350). When making the adjustments I wasn't able to get the draft setting into the "D" setting but able to go through LD and L. Are there any suggestions out there for the cause of this. I would really like to continue using this tractor for light field work but hydraulics are a must. Thanks for your help!
   / john deere 1520 hydraulics and draft settings #2
My guess is cam follower(shady outlined part) isn't in correct location in 3 pt linkage,is possibly broken or spring is broken. Either problem would require R&R of rockshaft housing.
I'll have to pull the cover off later this week and see what's going. Thank you for the help, I'm sure I'll be back with further questions.
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
