John Deere 110 backhoe tach help
   / John Deere 110 backhoe tach help #1
Steamroller69633
Hammonton nj
John Deere 110 backhoe, MF231s
I have a JD110 backhoe i think its an '06 but not positive. When i set the throttle at say 2000 and drive using the hystat pedals, intermittenly the tach drops to 0 and then the speed drops to a crawl. The actual engine speed never changes. Please help me troubleshoot if anyone can. Thank you
Also i should say that the machine sits alot and has only about 300 hours on it.
   / John Deere 110 backhoe tach help #3
Do you get any flashing code, its a book like symbol on the bottom left of the display and it will flash a code when there is a problem. Does it do it in any range? Are you working it or just driving, any more details could help. I will get mine to stop and turn the light on solid if I move forward on the seat to look at something. I think the tech stays up at the set rpm.
I will do some more research this weekend. I didnt notice the book icon. It only does it when im driving. It makes me think it has a wire rubbed through somewhere
   / John Deere 110 backhoe tach help #5
I just got a 110, but haven't heard of this problem. With the engine not dropping I'm guessing electrical, but where the problem is will be a bigger question of where and in what part of the electrical system.
2015 Hooper T/A Trailer w/ Mounted Foaming System (A50860)
2015 Hooper T/A...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 Nissan Rogue Select SUV (A48082)
2015 Nissan Rogue...
