John Deere 110 backhoe tach help
   / John Deere 110 backhoe tach help #1
Steamroller69633
Hammonton nj
John Deere 110 backhoe, MF231s
I have a JD110 backhoe i think its an '06 but not positive. When i set the throttle at say 2000 and drive using the hystat pedals, intermittenly the tach drops to 0 and then the speed drops to a crawl. The actual engine speed never changes. Please help me troubleshoot if anyone can. Thank you
Also i should say that the machine sits alot and has only about 300 hours on it.
   / John Deere 110 backhoe tach help #3
Do you get any flashing code, its a book like symbol on the bottom left of the display and it will flash a code when there is a problem. Does it do it in any range? Are you working it or just driving, any more details could help. I will get mine to stop and turn the light on solid if I move forward on the seat to look at something. I think the tech stays up at the set rpm.
I will do some more research this weekend. I didnt notice the book icon. It only does it when im driving. It makes me think it has a wire rubbed through somewhere
   / John Deere 110 backhoe tach help #5
I just got a 110, but haven't heard of this problem. With the engine not dropping I'm guessing electrical, but where the problem is will be a bigger question of where and in what part of the electrical system.
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Generac 15KW Generator (A50860)
Generac 15KW...
71067 (A49346)
71067 (A49346)
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
