John Deere 1025r
   / John Deere 1025r #1
Streetcar
Veteran Member
Cincinnati ,ohio
John Deere 870
Ordered new tractor
ordered 6’ MMM
4’ aerator
sprayer
loader and backhoe for tractor
   / John Deere 1025r #2
We will all be interested to see how long it takes to get it.
   / John Deere 1025r #3
Well at least you won't need the mower for 5 months or so. :) That's a nice set up congratulations.
   / John Deere 1025r
Plan to use tractor for maintenance task and back up mower for zero turn
   / John Deere 1025r #5
I just got one a couple months ago. Didn't know 72" MMM was an option. I have the 60". I can cut full speed in high range on normal lawn grass without much issue. For such a small tractor it sure does a lot of work! Rear ballast is your friend using the loader. I usually keep my rotary cutter hooked up and it still seems a little light in the back end. You will probably be fine if the backhoe is hoked up. Although be careful as I'm sure a lot of that weight is up high.
I really want to try a 5' rotary cutter on it. I'm sure it would have plenty of power but I'm not sure about keeping the front tires on the ground.
   / John Deere 1025r #6
5" should be no problem at all . . . :LOL:
2007 Pace American Enclosed Trailer (A49461)
2007 Pace American...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2013 Minos-Agri 190B Disc Mower (A50860)
2013 Minos-Agri...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Payment Terms (MUST READ) (A50774)
Payment Terms...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
