My tractor has the turf tires.
I wish I had the turf tires for mine, the ones I have on it tear the lawn to bits in the spring and fall when the grass is soft.
I use mine, not much mind you, in the woods, clearing snow and other odd things around. I've got a backhoe, which is not used too much but when you need it, it's better than a shovel ,
I made a scarifier for it, since I took this pic I added a drop down blade in front of the teeth so I don't have to take it off and put the back blade on when i want to level what I tore up
Only problem I've had was at 100 hours I had to split it, the cam bearing on one end was put in backwards so there was no lube oil going to the top end, tore the rocker shaft, arms all to bits.
I replaced the ignition switch as the factory one was flakey and added a few relays to control the glow plugs as well as the lights I added.
Check your air intake hose, the one going from the breather to the manifold. Mine made a sharp 90 deg turn and was starting to tear which would let dirt in so I made a steel tube bend which allowed me to use a straight piece of silicone rad hose.
.....Mike
