Mowing JD990 + NH 451 sicklebar mower
   / JD990 + NH 451 sicklebar mower #1
DPic105
JD 990
Posts: 31 JD 990 + NH 451
Need help!
Does anyone know how to hook up a NH 451 sicklebar mower to a JD 990 tractor??
I tried to do it today and found that the JD's three point hitch is too narrow at the top. I finally just used my top link to the frame of the NH, bypassing their set up, but also making it impossible to raise the mower.
DPic105
View Public Profile
Send a private message to DPic105
Find More Posts by DPic105
Add DPic105 to Your Buddy List
   / JD990 + NH 451 sicklebar mower #2
I also have a NH 451 mower as you described. On my JD 4500 I chained the top links together and just picked it up with a quick hitch. It worked ok, you just don't have the flexibility of the sickle going up and down as you raise and lower the mower. I am working on a solution to add a hyd. cylinder to do that.
John
   / JD990 + NH 451 sicklebar mower #3
John
Tried hooking up 451 sickle to my 3320 also, found your posts and was wondering if you found options to lift bar and attaching to top link ? Thank you
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
