JD4700 vs. JD 4710
   / JD4700 vs. JD 4710 #1
Anonymous Poster
Epic Contributor
I was planning to purchase a JD 4700 this Spring until I heard JD is coming out with a JD4710. Big difference I heard is the added electronic HST. Can anyone comment on this? What are advantages vs. disadvantages? Any other features with the 4710 that 4700 doesn't have? Thanks.
   / JD4700 vs. JD 4710 #2
Take a look at www.midlawns.com. They have all the info. on the new 4x10 series from JD. Personally I'd wait and get the new one unless you can get one heck of a deal on the 4700, like 30-40% off list. If not go for the 4710.
   / JD4700 vs. JD 4710 #3
Pro's would be very light HST peddle pressure, all your moving is a variable resister with a spring, Also it can be set so the full travel of the peddle changes the tractor speed only a very small amount for uses like rototilling, spraying ect. also can be set to maintain ground speed all by flipping switchs, The cons might be expensive to repair and you would probably need to take it to the dealer for most problems related to the Hydro due to the need to hook up to a scan tool to test the system, Mine is due here in the spring :)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2010 Chevrolet Equinox SUV (A48082)
2010 Chevrolet...
2014 John Deere 6125M Utility Tractor (A50657)
2014 John Deere...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
