JD1070 Driveshaft Shield
   / JD1070 Driveshaft Shield #1
wsp617
Wisconsin
JD 1070
I was operating on an asphalt road the other day when my 1070 started making a God aweful sound like the tranmission just blew up. I stopped the tractor and found I could still move. I drove the unit back to the house and started looking. Here the shield that covers the driveshaft (going to the front axle) had come loose in the front. When I got a close look at it I saw the shield had a like new decal on it with the part number. This made me think it's happened before. I just bought the tractor in June. All that broke was the tab on the front of the shield that secures it to the front axle.
Anyone know what would cause the thing to break? Are they a pain to change if I can't get the tab welded back on?
   / JD1070 Driveshaft Shield #2
I don't have first hand knowledge on the 1070 but, if the tab broke off the shield, the shield is getting enough vibration to flex the tab until it breaks.
Is there any way to add more support at a different place on the shield?
I was able to get the thing apart. A good friend of mine was able to weld the tab back on with an argon welder. Getting the driveshaft back on was a different story. Each end has a joint with 6 ball bearings. Of course they fell out when I took it apart. It took quite a bit but I was finally got it back together.
Looking back I was thinking I shouldn't have been it 4x4 on an asphalt road. On top of that I was coming down a steep hill. That may have caused some issues. Especially on a unit with over 5000 hours.
   / JD1070 Driveshaft Shield #4
Definitely not! That can really do series damage!
   / JD1070 Driveshaft Shield #5
Have you ever read the Owners Manual??
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
