3-Point Hitch JD x740 2WD pulling a box blade
   / JD x740 2WD pulling a box blade
yeah I've pretty much decided to put off the box blade idea due to the cost of the 3PH and blade are just not worth it to have a marginal performing setup. I'm probably going to take a close look at the drag harrows since I can use it for smoothing the area around a future pond after it's dug. At least that way if it doesn't work as expected for the driveway it probably won't go to waste. I'll still have to figure a way to ditribute new gravel and do some of the other jobs I had hoped to do with the box blade, but I'm not willing to gamble with $1500+ right now.
   / JD x740 2WD pulling a box blade #12
tiansberry,
You might be better off hiring the spreading of the gravel. I got a call this morning about touching up a driveway with my landplane and it is near where I will be working next week. For a job a few minutes away with out the need for loading and unloading I charge $100 to smooth a typical driveway up. Might find someone local who can do this for you.
   / JD x740 2WD pulling a box blade #13
I was planning on having the category-1 3-point hitch installed on my 2wd X740 then purchasing a 48" box blade from Everything Attachments. I want to maintain my 400' gravel driveway and also other uses such as clear and level areas for paver patios and walkways through my acreage, contour an area around a pond (if I ever get one dug), etc.
I had a New Holland 4wd TC30 with box blade, bush hog, and ph digger as my first tractor, but traded into the JD once the bush hogging turned into mowing around obstacles.
Before I spend the rather large sum to have all this done on my JD X740, I began to wonder if having only 2wd and turf tires would prevent me from having decent performance from the blade? If I need 4wd I'm pretty well screwed, but I'd rather know now than after spending ~$1500. The driveway (and the 12 acre parcel) are not flat - there aer some rollong hills, etc. Nothing real steep but near the end of the driveway it does slope down a decent amount. I use the 48" JD snow thrower in the winter using chains on the tires, wheel weights, and all extra rear suitcase weights to get traction. Any helpful comments appreciated.
I have a X740 with 2 sets of wheel weights and fluid in the tires, chains and a cat.1 3PT hitch. I have a center blade which works pretty well for grading things to level it out. I can get a pretty good gulp of dirt with that. I have a 6' read blade for grading the driveway down which worked fair to midland. That was cheaper than a box-blade and it seems to work. Since then I bought a 3720 I use that now for that stuff. I still use the 3 PT on the 740 for jockying trailers around and pulling other smaller ground engaging things like a smaller cultivator / cultipacker, and also lawn seeder/roller. I would have a difficult time not having a 3 PT hitch for as useful as they are. I wouldn't have a problem pulling a 48" box-blade with it. I'm sure a full box-blade would stop the tractor, but a 6' box-blade will almost stop a 3720 also.
   / JD x740 2WD pulling a box blade #14
Deere Dude,
I agree that the 3PH and rear pto are both very handy to have and I use about 10 small implements with mine but the OP didn't seem to be interested in other implements. When you have plans for rearblades, tillers, landscape rakes and spin spreaders it does make more sense to buy the hitch.
   / JD x740 2WD pulling a box blade #15
No, I would not, but it seems that his inquiry was about whether he could make this endeavor work with his current 740. I think he could with perhaps a tire change and maximal ballast. Whether the projects he mentions merits the amount of money he would spend I suppose would be a personal decision for him. I do not think either of us would do this personally because we are used to machines with 4WD, but I can say that when our driveway was gravel I smoothed it about three times a week to keep it tidy the way I wanted so a big chunk of my time was spent doing this job. I could see if this task is a big component of his use of a machine that it might be worth it to look at getting the equipment. At least in our area he could pay for the project with the sales tax difference he would have trading into a new four wheel drive machine to perform this duty. Our neighbor as a 455 with a 48" BB and bar tires with 72 pound starter weights and no fluid in the tires and can do quite a lot of work. His property is quite a bit flatter than ours and he is not as efficient but gets it done nonetheless.
John
(2) HYD CYLINDERS (1) 3" X 24" & (1) 3" X 12" (A57192)
(2) HYD CYLINDERS...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2018 New Holland C227 Compact Track Loader (A55315)
2018 New Holland...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
