JD X540 slow responding hydraulic
   / JD X540 slow responding hydraulic #1
M8560HD12 TAMMARC FARM
Bronze Member
Hamilton, OH
TS6.110 4WD Cab, WM75 FEL ROPS
My brother vinny owns a JD X540 and says deck is responding slowly when raising and lowering
Slower than what it had been
Fluid level ok
Time to drain fluid and change filter is first remedy i thought of
Any other thoughts
Wife thought air in line but that would chatter versus slow responding?
   / JD X540 slow responding hydraulic #2
I found that the rock shaft that is used to raise and lower the deck was tight. the deck actually needed pushed to go down, then due to the long slot in the bar from the hydraulic cylinder, it took a while to raise again. I found it when the deck was off and I noticed that I had to tug on the draft bars to lower those bars to remount the deck. Hope that helps. JW
   / JD X540 slow responding hydraulic #3
It could be air in the lines. Those small lines dont have enough fluid to vibrate. I would check out the linkage to the raise lower lever maybe it is wore and not moving the control mechanism as far as it should.
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
UNUSED 2-Ton Lever Block (A50860)
UNUSED 2-Ton Lever...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
