JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #1
kw1600
washington
johndeere x324
Over two yrs, i have had a proplem when mowing. when cold pto engages intell it get warm. stop to dump grass. wont engage. cools down. will engage intell it gets warm, just put in a new jd clutch. still having problem. 500hrs on tractor. checked elect plugs. battery voltage. Is there a coil thats controlls the clutch?
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #2
SO---- What was the battery voltage? When stopped and when running?
well. i will check it tomarrow. when i mow. thank you
checked voltage. before start up. 12.88v. running 14.19v. pto engaged 13.06. pto kicked out 14.06v
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #5
Huh... well, there goes THAT theory~! IF you hadn't mentioned a new clutch, I'd have suggested that first. I GUESS that it's not IMPOSSIBLE for you to have a bad clutch pack - but with you just replacing it, unlikely...
Can you hook up parallel leads to the clutch electrical plug to measure voltage THERE, AT THE CLUTCH, while you're running?
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #6
Try bypassing the wires going to the clutch. Jerry rig some wires and a simple switch directly to the battery. Even though it acts like its a temperature related issue it could be a loose or broken wire/switch/connector/ground that acts up occasionally. I have had this type of thing stump me for days. Once a person thinks they know what the problem is, it is sometimes hard to step back and look at other possibilities. Happens to me all the time.
good luck
   / JD X324 RIDING LAWN MOWER. WHEN WARM. PTOVWILL NOT ENGAGE. HELP #7
I have a X740 that will get hot from mowing and the PTO kicks out even though I pull the PTO switch before I back up. I found the problem was grass packed all over where it shouldn't be. It is water cooled and I have a temp gauge, but maybe you have a something plugged up causing it to heat up enough to where the electronic system kicks out the PTO. Just a thought. :confused3:
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2018 Ford F-150 4WD Pickup Truck (A50860)
2018 Ford F-150...
2019 Fontaine Traverse HT T/A 48ft Loyboy Trailer (A49461)
2019 Fontaine...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2011 MACK GU713 (INOPERABLE) (A50854)
2011 MACK GU713...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
