JD spacer: M121019, lost it.
   / JD spacer: M121019, lost it. #1
Zephrant
Spokane, WA
JD 2210
Took apart the snow blower belt drive thing because it got all bent up over the years last spring. Somehow lost the spacer that goes on the shaft before the pulley.
I know it’s a 1” shaft, but I’m not sure how long the spacer needs to be. Without reassembling I can’t easily measure, and it’s a lot of press work to assemble.
Anyone got any ideas as to the length of that spacer?
Part 29: M121019 - SPACER 1" SCH40 BLK PIPE . fits JOHN DEERE | Price: $10.42 Stock: Wisconsin
Or is it 1” in both dims?
Ended up making a 7mm spacer, and put it together. Was not clear which side of the A frame the bearings mounted to. I went front one inside, rear outside.
Working now though.
2020 Peterbilt 579 Day Cab Truck Tractor (A50860)
2020 Peterbilt 579...
Heavy Duty Forklift Plate and Forks (A50860)
Heavy Duty...
2020 KUBOTA RTV...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
Unused Delta Crash...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
