JD 855 with no electrical power
   / JD 855 with no electrical power #11
New cables. High current and old cables. Same thing happens to my 4300. The cables arc to the point of infinite resistance. I replaced the cables with factory cables and cleaned the ground to the frame. Works like a charm! Good luck!
   / JD 855 with no electrical power #12
I had this exact same problem yesterday. Does it every once in awhile. Every single time, cleaning the battery terminals has corrected it. I do plan to replace the cables at some point. Have the stuff on hand, just need to find the time.
After looking at my battery it's a lot older than I had thought. Probably replace it prior to winter rather than hope it lives.
   / JD 855 with no electrical power #14
I followed your advice. Pulled the terminals. They were still clean from a couple of months ago, but I cleaned them again. As I was reminded by another person, 12.5 volts is not a stellar battery. I replaced the old battery with a new Legend battery from NAPA, and the 855 came back to life.
Thanks again for all the help. I really do appreciate it.
Ed
If it reoccurs you may have an ignition switch failing. My 855 was failing to start intermittently. I could jump across the contacts at the starter and it would work but not from the switch. Unplugging and spraying the ignition switch would bring it back to life. I eventually replaced the switch and haven't had any more trouble out of it.
2015 Chevy Equinox (A56859)
2015 Chevy Equinox...
2007 Ford F750 (A55973)
2007 Ford F750...
2009 Ford Ranger Pickup Truck (A55852)
2009 Ford Ranger...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
Metal Sunfower Lawn Art (A55853)
Metal Sunfower...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
