Backhoe JD #7 Backhoe Serial # Location?
   / JD #7 Backhoe Serial # Location? #1
Maynah13
Central Maine
JD 750
Hi, new member here. I just acquired a JD 750 with a JD #7 backhoe and was trying to get a manual from JD. It seems there are two, depending on the serial number. I looked all over but can't seem to find one. Can anyone tell me where to look for it?
Thanks,
Robert
   / JD #7 Backhoe Serial # Location? #2
I thought it was on the boom...what did your local JD dealer say?
   / JD #7 Backhoe Serial # Location? #3
I'll check tonight when I get home, unless someone else posts between now and then. I don't recall that it is on the boom, I'm thinking somewhere on the main frame that holds the swing and operators platform.
Thanks.
My dealer said he'd get back to me but I haven't heard from him yet.
JD says the location is in the operators manual...:rolleyes:
I found a manual for sale dated 1991 that was for the early set of serial numbers. Since my tractor is dated 1987, I assumed that this was likely the correct manual and ordered it. Hopefully, the manual will help me verify that I made the correct choice.
   / JD #7 Backhoe Serial # Location? #6
I totally spaced looking last night Maynah, sorry about that. I should have an easier evening tonight.
Forgot to congratulate you earlier on your acquisition. You'll have a blast with it for sure!
   / JD #7 Backhoe Serial # Location? #7
The ID tag is supposed to be located down on the side plate of the swivel area at the swing frame. I say supposed to because mine does not have one. As far as the owners manual is concerned I bought one on e-bay pretty cheap. It was for a 750 and they seem to be readily available. It has some basic info but not a lot of details which is good for a guy like me who suffers from short term memory loss. If you find one for a 770 I will trade you.:D
JD 770 / 70 FEL / 7 BH - 425 AWS / 54" MMM / 54" FMP
   / JD #7 Backhoe Serial # Location? #8
Checked mine tonight and as Whitey said the ID tag is on the main frame. If you are behind the tractor/backhoe it is on the right side, between the boom swing pivot and the RH stabilizer pivot, down low. Two rivets, so if you don't find the tag look for rivet holes where it may have been. I have the operators manual, parts manual and hydraulics manual to cover if you have any questions.
Enjoy!
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
