JD 5100e engine problem. Dealer doesn't know what it is.
   / JD 5100e engine problem. Dealer doesn't know what it is.
jd110, I have had codes for low fuel rail pressure before. They were addressed by changing out the filters. This is what I thought was going on this time, but new filters did nothing.
The first tech (from a different shop) who came to look at it said there was nothing wrong, but only started it up and ran it for a few minutes. When I explained to him it happened a little after it warmed up and under load, he came back out and said the tank was full of gasoline and that was the cause. I know this wasn't the case, but I drained it completely anyway. (It was diesel).
I ended up calling the other shop in town and having them send their tech out.
   / JD 5100e engine problem. Dealer doesn't know what it is. #12
   / JD 5100e engine problem. Dealer doesn't know what it is. #13
While “In E-PTO” & engaged : the motor won’t rev past about 1850rpm
im sure you know this tho.
it’s designed so you can’t over-Rev implements on these newer JD with electric throttles
   / JD 5100e engine problem. Dealer doesn't know what it is. #14
Best I remember : my 2018 5115M won’t Rev but about 2400rpm : I’m thinking
This isn’t just limited RPM, but sputtering and surging.
   / JD 5100e engine problem. Dealer doesn't know what it is. #16
It would be interesting to know which engine type it is. You're not stating a model year. There are quite some diffrent models on the market, they're all called 4045's.
I had similar codes on a 2012 6430 premium. Low fuel rail pressure. A new suction control valve solved the problem. It's a common rail engine.
KOMATSU WA270 (A58216)
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
