Buying Advice JD 5075E vs Kubota 7060 both with cabs
   / JD 5075E vs Kubota 7060 both with cabs #1
unclebilly
Blackie, AB
Case 2670, JD400 Backhoe, Kubota M7060
I have seen some comparisons on the OOS tractors but want input on the cab'd machines.
I travel a lot with work, we have cows and 2 small children. I need a machine that my wife can hop into when it is -30 (with kids in tow) and feed the cows a bale of hay. I also want ot pull a baler, swather, mower, and rotiller (maybe).
I have looked at:
Case FarmAll 75 - front axle not up to handling big bales (this is from CASE depsite the brochure showing 4 photos of these tractors hauling bales).
New Holland - same as case.
Kioti DK55 ad 90. The closest dealer is nearly 100 miles away. The cost savings are attractive but...
LS - I have spoken with the dealer, also 100 miles away.
McCormich X60.30 - way bigger machine but the pricing is attractive but the resale seems to be bad on these.
John Deere 5075E - we have 2 dealers. One won't honor their advertised pricing, the other won't have stock for several months.
Kubota 7060 - this was the first machine I looked at.
I am down to Deere 5075e and the Kubota 7060. Pricing is similar. Kubota has a better warranty (5 years on power train). I think Deere may have better resale - this is green country. The Deere is quite a bit smaller but seems to be as capable albeit with lower PTO HP. The Deere is made in India (even the injection pump is made in India) whereas the Kubota is Japanese. The Deere is Teir IV interim whereas the Kubota is TierIV. On paper these tractors are very similar.
What say you guys - should I buy the Deere or the Kubota? What was the deciding factor for you? A 5085E is only $6000 more but i dont know I would need to make that jump.
   / JD 5075E vs Kubota 7060 both with cabs #2
Those are the two machines I have been comparing lately. Deere or Kubota are my only reasonable dealer choices.
It's probably a software glitch, but on the "Build My Kubota", it won't put R4's and a loader package on the same machine. :confused: For your use, you probably would rather have R1's anyway.
   / JD 5075E vs Kubota 7060 both with cabs #3
I have looked at:
The New Holland T4.75 and it's red headed step child of a cousin are more than capable of handling big bales. I have sold many since they have been out for the sole purpose of being loader tractors to load/unload roundbales....mostly 5' x 6' bales at that. It really does compare better to the 5083e or 5085e. The 5075e is a price point Indian tractor....don't get wrong I have one too. They are great for certain people doing certain task but I'm afraid you would out match it. If you are crazy enough not to by a Blue one! ( I'm kidding but do give them another look and speak with a dealer that knows his product) I would strongly recommend a Kubota....load the tires and throw some wheel weights on and you have a machine that would run circles around the inferior 5075e. My two cents....
   / JD 5075E vs Kubota 7060 both with cabs #4
Comparing those to models isn't quite right as the Kubota is a higher end tractor. Many of the majors have been building economy tractors, ie, 5075E to compete with the Kubotas. All you need is to have the two next to each other and run a sound test. With the deere anyone I know wears ear protection with them.
   / JD 5075E vs Kubota 7060 both with cabs #5
i was in the same boat as your in now back in july.i had a mx5100hst 4x4 fel that was bought new in 2010.we used the tractor to feed hay with moving 5 by 6 an 4 by 6 bales.then this we bought a 5 by 6 baler to bale our own hay.an that baler puts up bales that weigh 1800lbs or more.an the mx5100 was strugging to pull the 4 bale hay hauler an pick up those heavy bales.so in july i traded for a new 7040SU with hydro shuttle an it lifts the bales no prob an pulls the 4 bale hay trailer no prob.
   / JD 5075E vs Kubota 7060 both with cabs #6
With similar pricing and Kubota being the higher end tractor, I don't see any choice but the Kubota. Kubota's hold their value very well, even in Green country.
Looks like I am going with Kubota. The JD dealer agree to honor their original price while I was on my way back to the Kubota dealer to strike a deal. My wife prefers the Kubota and it is loaded. It has the cold climate cab (100A alternator, rear defrost, rear wiper, weights, air ride seat). Is there anything else I should consider?
   / JD 5075E vs Kubota 7060 both with cabs #8
How many remotes are you getting, hydraulic top-link, bucket hooks?
   / JD 5075E vs Kubota 7060 both with cabs #9
3rd function hydraulics for the FEL? I would want this to be ready for a grapple.
   / JD 5075E vs Kubota 7060 both with cabs #10
Load the rear tires. And I would want 3 sets of hydraulic remotes for the rear, at least for my uses (one set for a grapple, 2 sets for a hydraulic top link and side link).
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
Auger with Extension (A50860)
Auger with...
Anvil (A50860)
Anvil (A50860)
Mitsubishi FGC20K Forklift (A50860)
Mitsubishi FGC20K...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
