JD 450C Clutch Housing Oil Change??
   / JD 450C Clutch Housing Oil Change?? #1
Flatheadyoungin
Veteran Member
Southern, OH
New Holland TC45 Shuttle
Ok, I've changed just about all of my fluids in the 450C. However, even with the book, I just don't understand how to change the clutch housing fluid. I see what looks like two drain plugs but I can't seem to locate the fill hole for each side.
Any ideas?
   / JD 450C Clutch Housing Oil Change?? #2
When you say two drain plugs, are you talking about the ones down by the final drives? There is a drain on the inside of each final drive, under the machine, they like a pipe plug. The two fill plugs are also a pipe plug that are facing rear of the machine, about 8 inches off the ground. I believe you just fill them until the fluid runs out of the hole.
There is a different set of filler plugs that are right above the tracks and 12:00 from the rear sprocket. Most of the time you can't see that plug because the area is ususally packed in mud/dirt.
I'm not sure if those are the holes you are looking for, but thought I would put in my .02 cents.
Yeah, I didn't get to finish my thread, I had to chase the kids!;)
I changed the final drive oil in both sides. You're right about the mud. I carried a small flathead screwdriver to clean them out.
On further back (underneath), there are two more similar drain plugs. I think they are for the steering clutches but they would only be good for draining because they are both on the bottom most point of the housing. So, I assume they are for draining. I can't, however, find the fill holes.
So you think the fill holes are on the outside near the sprockets. I saw some very large pipe style plugs on the side of the dozer (can't recall exactly where) but I think they are for adjusting the brakes or something.
It's out to the property, so it may be the weekend before I can check it out. In the mean time, any advice you give is great! Also, I'll look back through the factory service manuals.
   / JD 450C Clutch Housing Oil Change?? #4
clutch housing oil, are you talking about the torque converter ?
In most wheel loaders, the TC has a common sump with the powershift. (speaking ZF powershift but a Deere probably has a Funk powershift)
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
Two Post Car Lift (A50120)
Two Post Car Lift...
