JD 4320 Test drive issues (Brakes, Hyd pump)
/ JD 4320 Test drive issues (Brakes, Hyd pump) #1
svdsinner
JD4020 w/46A Loader
Just drove a 4320 I really liked, but it had 2 issues I've got questions on:
1) The brakes gave a really weird kickback sensation when I pushed on them. Basically, when I pushed the brake pedal all the way down, the pedal would suddenly push itself back up about an inch. Any ideas what this could be? (Happened on both L & R)
2) The hydraulic pump was making a knocking sound, and the 3pt would move jerkily to the rhythm of the knocking when being raised/lowered. I've seen this before on a 4020, and I can't remember the exact cause, but I think it was a cheap repair to the bottom of the hydraulic pump. Anyone know the specifics on this and what it takes to repair?
/ JD 4320 Test drive issues (Brakes, Hyd pump) #2
Two things I would check on the hydraulics, the inline filter on the pump lower side in the suction line and the transfer charge pump in the rear base. From your description it sounds like a restriction or low flow issue on the inlet side of the hydraulic pump.
Before buying I would also perform a pressure test of the hydraulic system IIRC should be about 2200 psi.
About the kickback on the brakes, I had a 3020 diesel that did this but the brakes worked for years without issue.
/ JD 4320 Test drive issues (Brakes, Hyd pump) #3
I've noticed the brakes on my 4320 do the same thing but work as expected and hasn't been a problem for over 2 years now.
All I can say about the Hydraulic problem is mine doesn't do that. Good luck.
/ JD 4320 Test drive issues (Brakes, Hyd pump) #4
I thought JD brakes were supposed to do that
/ JD 4320 Test drive issues (Brakes, Hyd pump) #5
maybe check the linkage between the engine and pump. I have already seen them come loose and rattle around
/ JD 4320 Test drive issues (Brakes, Hyd pump) #6
I have had the brake pads desinigrate and plug the suction filter on the internal pump. It was really expensive to part the tractor to repair the pump. That pump provides fluid for the steering and power brakes and to the main pump up front I think. The 3 point lift will chatter like that after sitting until fluid gets pressure thru the system. Make sure you don't start it with the clutch depressed as that pump is after the clutch on this model and it won't get oil to the front pump. That was one of the major changes going to 44 series.
/ JD 4320 Test drive issues (Brakes, Hyd pump) #9
good point, I assumed a real 4320 since this is in the ag section.
I assumed the bigger tractor as well. JD does have a couple of models of tractors with the same number although 30+ years apart. Same with some sprayer models and CUTs.
/ JD 4320 Test drive issues (Brakes, Hyd pump) #10
I assumed the older 4320 since he asked about the brakes surging, the older model had hydraulic brakes the new 4320 CUT had mechanically applied brakes.
Shhould point out that the OP has not replied since Nov 9 2010.
/ JD 4320 Test drive issues (Brakes, Hyd pump) #11
The knocking noise is probably worn bushings(R45822) in the main hyd pump coupler.
/ JD 4320 Test drive issues (Brakes, Hyd pump) #12
I had the same problem, and it had to do with a posting about a Deere 820 in the Ag Forum. Turned out it was the 820 CUT, not the big 820 2 cyl diesel. Took awhile to figure that out, but initially a bit misleading. But it happens. :)
The OP was on the forum Monday of this week. Maybe he couldn't find this thread again.
