JD 4105 Transmission noise
   / JD 4105 Transmission noise #1
Jcali
Northern Arizona
JD 4105
I recently bought a John Deere 4105 Compact Utility tractor. This was an upgrade from my late-1970s Massey Ferguson 230. Tractor was delivered and I read the manual and got on. I put the gear in high and drove around and I am noticing a grinding noise from the transmission when I am in motion. I do notice it's not so bad when I'm in Low speed and I wanted to know if this is normal. Perhaps this is normal with the hydrostatic transmission. Any input would be greatly appreciated.
Thank you,
Jarred
   / JD 4105 Transmission noise #2
I have a 4105 and in high range the trans is very noisiey to sounds like it is screaming and hope we do not see a problem from that but we shall see. Have you had any problems with yours kicking out of 4 wheel drive when
Backing up and turning the wheel ?
1995 Ford F-700 Flatbed Truck (A50860)
1995 Ford F-700...
2016 Big Tex 12ft. S/A Utility Trailer (A48082)
2016 Big Tex 12ft...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2012 Ford Focus Hatchback (A48082)
2012 Ford Focus...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
