JD 4105 CUT
   / JD 4105 CUT #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
Does the JD 4105 CUT have an aluminum rear end? My 3320 does and I am thinking about trying to get away from aluminum.
   / JD 4105 CUT #2
I wouldnt let that scare you. Engines are made out of aluminum today, think about all the componants in an airplane. I see a lot of aluminum transmission and axle housings these days on multiple applicaitions.
   / JD 4105 CUT #3
The 4105 does have an aluminum rear end. You have to move up to a 4x20 to get all steel, and planetary final drives. I also prefer steel, but I don't hear of any failures of the aluminum either.
   / JD 4105 CUT #4
I have stayed with the "tried and true" 655-755-855-955 CUT because of the lack of issues with castings, hydraulics, engines, electricals?etc? As you can see from my avatar? have owned ALOT of them?pleased with everyone, only reason to sell is for more HP as I have begun to do small farming?.LOVE them?o/little electronic sensors and one of my buddies has a small fleet of repaired JD's he has fixed (broke castings, and dealer can't braze them)?he is personal friends with JD shop owner and gets all the MAJOR broke/burned ones?One of his is a 4120 or 4110:thumb down:
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2022 Club Car...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
UNUSED 20PCS 1.2 in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 1.2...
