jd 4020 headlight switch wireing
   / jd 4020 headlight switch wireing #1
quickilverauto
1968 john deere 4020
need to know if anyone has schematic for headlight switch (tractor is now 12 volt
:confused:
   / jd 4020 headlight switch wireing #2
You should be able to find it at Deere.com or I picked one up at the local Deere dealer when I needed it to fix my friends 4020 light. I don't know where they are now, or I would scan and send.
   / jd 4020 headlight switch wireing #3
If it were me I would rewire the lighting circuits on a machine with that much age. The wiring wasn't protected that well and new sleeving and wire would eliminate alot of future problems with it. At the least I would go over the wiring with a fine tooth comb looking for abrasions and cracks. This is a low cost problem solver imo.
   / jd 4020 headlight switch wireing #4
What year? Was it originally a 24 volt system?
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
Toolbox (A50860)
Toolbox (A50860)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
