Snowblower JD 3320 MMM Rear Hydraulics to Rotate Rear Snowblower Chute
   / JD 3320 MMM Rear Hydraulics to Rotate Rear Snowblower Chute #1
KennK
NE Wisconsin
John Deere 3320
I have a John Deere 3320 purchased in 2006 with a mid mount mower (now removed) and the two rear hydraulic connectors that I assume drive the mower lift/lower.
I'm thinking about buying a Woodmaxx snowblower, and I'm wondering if I can disconnect & cap the rear hydraulic hoses that I think lift/lower the mid mount mower (the MMM is not on the tractor) and connect/use the rear hydraulic ports to rotate the snowblower's output chute.
The MMM lifts/lowers using a lever on the right side of the seat (next to the rear rocker arm lift/lower), so I assume it would be able to rotate the chute by pushing/pulling that same lever.
Any advice/insight you can give would be very helpful.
   / JD 3320 MMM Rear Hydraulics to Rotate Rear Snowblower Chute #2
Yes, I would think you could use your rear remote for your snowblower.
2019 Ford Explorer AWD SUV (A48082)
2019 Ford Explorer...
Marshell GML C2+2 Electric Cart (A48082)
Marshell GML C2+2...
Dozer Blade Attachment (A50860)
Dozer Blade...
2025 K1220 UNUSED Single Garage Metal Shed (A50860)
2025 K1220 UNUSED...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
