JD 332 skid-steer and log splitter
   / JD 332 skid-steer and log splitter #1
jklingel
Simple question. I am about to receive an '04 JD 332 skid-steer, and am wondering if I will be able to operate a log splitter from outside the cab, like I've seen Bobcats set up to do. Yes? No? I know I'll need a valve, etc, just don't know if I can get pressure to the aux line if my butt is not in the seat. (I will be embarrassed beyond measure if I already asked this here....) Thanks. j
   / JD 332 skid-steer and log splitter #2
Couple of things to know about the skid-steer and the log-splitter. What type of hydraulic's are present in each?
Does the skid-steer provide "open-center" hydraulics? Does the log-splitter require an "open-center" hydraulic system to operate?
My log-splitter ran from the 3pt on my tractor and worked off the "open-center" hydraulic system available at the power-beyond circuit used for the back-hoe attachment.
Of course, there's the niggling details regarding the type of hydraulic couplers' as well. But, first you need to determine what system of hydraulic funtion is needed (log-splitter) and available (skid-steer).
Open-center or closed center hydraulic system. Your owner's manual for the SSL and the log-splitter should give you a good idea as well as possible locations on the web to gather more complete info if necessary.
Good luck.
AKfish
   / JD 332 skid-steer and log splitter #3
The TSC type (Speeco) splitters come with the conversion kit for open or closed center systems--I think that they are usually shipped set-up for open center.
AK and B8: Thanks for the leads. I don't have the loader yet, so I can't look that up, but now I know what to ask. All I know so far is that it does have auxiliary hydraulics, and I have seen Bobcats running splitters from outside the cab. I will build the log splitter as soon as I find out what all I need. Thanks again for the replies; I am steered better now.
2017 Ford Escape SUV (A48082)
2017 Ford Escape...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
434669 (A48836)
434669 (A48836)
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2011 Ford Fusion SE Sedan (A48082)
2011 Ford Fusion...
