JD 2305 Repetitive Diode Failure
   / JD 2305 Repetitive Diode Failure #1
Samw41240
Eastern KY
kubota m7040 JD 2305
Engine will not start. Replace fuel solenoid diode. Engine starts and runs fine for 1 to 30 minutes then dies and will not start. Have replaced diode 3 times with same results. Any help on what may be causing the diodes to keep failing?
   / JD 2305 Repetitive Diode Failure #2
Bad ground. Had the same issue with one of my Kubota's Cold not figure it out, finally my Kubota tech discovered the issue.
Is the frame ground from the negative battery terminal the only ground location?
   / JD 2305 Repetitive Diode Failure #4
On my M9000's? no. there are a couple grounding points on the units.
2007 Jeep Compass Sport SUV (A48082)
2007 Jeep Compass...
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
2010 Toyota Camry Sedan (A48082)
2010 Toyota Camry...
Misc. Electronics (A50860)
Misc. Electronics...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2022 Club Car...
