JD 2305 box blade question
   / JD 2305 box blade question #1
markhait
Milford, Michigan
CubCadet LT50, John Deere 2305
I've got a 4' box blade and so far it's doing what I need, but I'd like it to be a little more convenient for me.
I called the JD dealer near me and asked him if I could install a hydraulic top cylinder. He put me on hold for a few
minutes and came back to say that the salesman said no. There is no rear hydraulic port to operate a hydraulic top cylinder.
I know that there isn't rear ports, but I figured that you could probably piggy back off the FEL and run some back?
Is this something that can be done or not? Maybe the tractor doesn't have enough power?....that doesn't even sound right
since I'd only be using one or the other at a time. I have been talking with Brian at Fit rite hydraulics, but he's even
talking over my head a bit since I have no idea how any of this would work or how I would even ask for what I need.
Plus they have a huge back order right now of over 14 weeks!
Basically, can it be done, what would I need and how would it get hooked up?
Thanks for your help in advance!
   / JD 2305 box blade question #2
A 14-16 week back log are the current lead times. :eek:
Yes this can be done, I pointed you to your dealer to check to see if they had a kit for your tractor. Apparently not, or they simply did not want to be bothered. Typically a single OEM rear remote set is less $$ than what I can provide.
If you want to use a diverter and just use your loader valve as the controlling valve, this is not a problem. I don't think that you are going to find a "kit" for what you want to do though. :( Parts can be either provided or you can piece something together yourself and save some $$$, but either way you are going to have to do more than just install a "kit" and it will be a multi stage process.
Contact me again or probably quicker, Ken at Ken's Bolt on Grab Hooks <<Home>>. Either of us can get you through this so that you end up with a truly usable box blade. :thumbsup:
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
19 Monitors (A48083)
Lot of 5 Laptops (A48083)
Lot of 5 Laptops...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
1000 Gallon Water / Chemical Tank (A50860)
1000 Gallon Water...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
