JD 2210 bent or misaligned rear PTO shaft
   / JD 2210 bent or misaligned rear PTO shaft
fgross335 2210:
Thanks for the referral to ytmag.com. I checked it out and posted a reply to the original poster with the similar problem. His seemed much worse, although "off axis" is "off axis" and its still a problem no matter how you slice it. He indicated his was off by about 15-deg. whereas mine is off by about 1-deg. and had to check it multiple times to make sure it wasn't an illusion The slip clutch issue raised by the guy on ytmag.com is any interesting one and makes me wonder what kind of shape the slip clutch on my rental was in. If anyone else is interested in this poster's piece, go to ytmag and search under "2210 PTO." His piece is entitled "2210 PTO catastrophic failure!!!"
Anyway, thanks again
JDLou
   / JD 2210 bent or misaligned rear PTO shaft #12
Have you tried a dial indicator on it to see how far out it spins?
I'd agree about the slip clutch. My 455 has an internalclutch on the PTO that makes a loud ZZZZZZZZZZZZZZZ prior to stalling the engine when the tiller gets bound on a rock. I can imagine what would happen w/o this clutch....
   / JD 2210 bent or misaligned rear PTO shaft #13
A slip clutch is a must on a tiller. If it was a rental you can bet the clutch has never been adjusted or checked very much. I adjust mine so that i can , with some effort, turn the tines without the pto shaft turning, I would rather replace a clutch disk than the rear PTO shaft and gears.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
1994 John Deere 544G Wheel Loader (A55272)
1994 John Deere...
2018 DRAGON 53FT FOUR AXLE HEAVY HAUL TRAILER (A58214)
2018 DRAGON 53FT...
8' Avalanche Snowbox (A55272)
8' Avalanche...
NEW HOLLAND TS115A TRACTOR (A58375)
NEW HOLLAND TS115A...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
