jd 2140 hydraulics
   / jd 2140 hydraulics #1
mikeparks
unipon grove al
looking at a 2140 4x4 cab tractor. loader up and down hooked to one set of rear hydraulics. loader is slow up but very slow down. v rake hooked to
other set of rears works fine. any thoughts on what problem could be.
   / jd 2140 hydraulics #2
Ind loader valve should be plumbed directly to tractor hyd system not through remotes(scv) and return oil back to hyd ported filter cover for optimum operation.
   / jd 2140 hydraulics #3
Hydraulics:
Type: closed center
Capacity: 11 gal [41.6 L]
Pressure: 2466 psi [170.0 bar]
Valves: 1 to 3
Pump flow: 12.4 gpm [46.9 lpm]
Total flow: 10.3 gpm [39.0 lpm]
There is no particular reason that it should not work using the rear remotes, as the ports are the same.
The retract stroke should be faster in all situations.
Perhaps something is blocking the flow such as a crushed line, damage fitting, perhaps someone put a restrictor in one of the fittings.
A valve like this would better suit you better.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
BRAND CLOSED CENTER KIT
   / jd 2140 hydraulics #4
Routing return oil to hyd filter ported filter cover should help cycle time.
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
