JD 2010 PTO
   / JD 2010 PTO #1
gpike19
romulus, mi
john deere 2010
I have a 1961 jd 2010 (gas) this tractor was used exclusively at several nurseries. at some point in time there was a front loader added to the tractor. to get to the point here, the pto and 3 point were rarely if ever used. I am now looking to buy a new bush hog, pto driven. my question is how can I tell if the pto is still operating normally, other than just watching it rotate? are there seals that might leak? or bearings that might have failed at some point? I don"t want to invest in the bush hog, just to find out the pto no longer functions. I am new to owning a tractor. any help here would be appreciated. thanks
   / JD 2010 PTO #2
With engine running engage pto to see if shaft turns and no load noises are emitted. It's normal for 2010 pto to make a gear clashing noise when clutch is being engaged.
   / JD 2010 PTO
hello tx Jim thanks for the reply. yes I engaged pto and shaft turns smoothly with very little noise. seems to be ok.
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
