jd 2010 power loss
   / jd 2010 power loss #1
west7323
LaFayette , NY
john deere 2010
I have a jd 2010 1963 i think. It seems to bo a little down on power and blows smoke out the breather tube pretty good. the last cylinder up near the radiator fouls out too every so often. it smokes heavy when it is worked hard. antifreeze seems to stay up and oil seems clean. why the smoke and power loss? could it be head gasket? where should i start?
   / jd 2010 power loss #2
I would change your air and fuel filters first. If that doesn't work make sure it is getting fuel to the filter and have the fuel injectors checked.
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
2016 John Deere 6110M Utility Tractor (A50657)
2016 John Deere...
2020 KUBOTA RTV...
Pallet Forks - Clamp On Attachment (A50860)
Pallet Forks -...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
