JD 1070 clutch noise
   / JD 1070 clutch noise #1
ndgregor
Wind Gap, PA
John Deere 1070
I have noticed the following going on with my JD 1070. MFWD and roughly 1500 hours.
When the weather is cold out (below 40 F), when the tractor is started and initially put into gear upon releasing the clutch there is a slight grinding noise that comes from the transmission. This is not a grinding sound as if you were jamming it into a gear, more of a soft grind/rubbing sound. It starts as the clutch begins to engage and stops once the clutch is completely engaged and the tractor is moving. You can feel a slight vibration through the clutch pedal. I have also noticed that once a few shifts are made, and the tractor is operated for a bit the noise goes away entirely. While it is cold, the noise is more pronounced the higher the gear that you start in. There is no noise when engaging the clutch in neutral.
No performance issue has been detected, and I was able to pull a 2x12 plow two weeks ago through tough ground with no problem. Any thoughts/ideas?
   / JD 1070 clutch noise #2
For the age of the tractor you might have the clutch shaft getting dry or parts in the transmission. To only have when cold, metal is a different size and it might not be a real problem. the transmission is up to proper level?
   / JD 1070 clutch noise #3
Maybe the throw out bearing is dry? Or as stated, slight galling of a dry input shaft.
Jim
   / JD 1070 clutch noise #4
Cooler weather could make the TO bearing stiff until the grease is warmed up and makes it easier to spin. Or it could be on its way out. Warmer weather will tell. For time being id engage at a low RPM
2013 John Deere 640FD Flex Draper Head (A50657)
2013 John Deere...
Hydraulic Breaker Excavator Attachment (A49461)
Hydraulic Breaker...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2011 International School Bus (A49461)
2011 International...
2017 Chevrolet Silverado 2500HD Crew Cab Pickup Truck (A49461)
2017 Chevrolet...
